09-10-2011, 02:51 PM
il
Cobra Make, Engine: Street Beasts/5.0 Jon Barrett Hot Rod Engine
Headlight issue
Guys...my headlights went out on the way home from volo last sunday. when i turn on the swith i get just a flicker and they immediately go off. i can hear the breaker trip as lights flicker for that split second. i tried a new switch,new breaker and checked bulbs...none burned out...lights are not wired to a relay but run thru the 30 amp switch...original builder of the car used steering column from early 80's camaro so dimmer works from turn signal stock...could a bad dimmer switch in the column cause a problem like this?
any input will be welcomed.
Thanks.
Jerry
