Here's a method of mounting the fire extinguisher that doesn't require drilling holes . . . and it's right there if you need it. I mounted the fire-extinguisher bracket to the roll bar with two stainless-steel hose clamps.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
