07-16-2013, 04:40 PM
Ca
Or, you can do it the scientific way, gravity bleed. I've used this method many times for bleeding the clutch slave cylinder, where the master is sitting higher than the slave. Don't use on your brakes. Remove top from fluid reservoir, crawl under car and open bleeder valve after placing a container under it to catch the old fluid. Fluid will slowly drain from reservoir to bleeder valve. Refill reservoir a couple of times (you do not want to let any air into the system from above) tighten bleeder valve and voila, old fluid is gone, no air in system, and you barely got dirty. Or you can do as suggested above.
And yes, it does work. Many of us do it this way.
Jim
