Originally Posted by glenninsandiego
After looking closer at the windshield on my Arntz replica
I found these numbers at the bottom of the glass
KVW 105 B2 (it may be R2 at the end)
VIRACON
Safety Float
ASI M40 DOT 129
It measures about 47 inches across the top and about 54 inches across the bottom and 14.5 inches top to bottom in the middle these numbers are including the glass covered by the frame.
Any ideas on where I could get a replacement or who might I ask about a replacement?
Thanks for any leads
Glenn in San Diego
Let's decode that:
KVW 105 B2: not sure what that means.
Viracon: This mark identifies the manufacturer, by their name and/or logo (“the manufacturer’s distinctive designation or trademark”).
Safety Float: Often, the trademark name of the glass is present.
AS1: Not ASI. The AS number stands for American Standard, and is “AS” (or “American Standard”) followed by a number indicating the position in which the glass may be used, based on its optical quality. AS1 is the clearest glass (at least 70% light transmission), is laminated, and can be used anywhere in a motor vehicle (typically just the windshield)
M40: "The M number is unique to the manufacturer, so one an M number of M312 by one manufacturer could be different than glass labeled as M312 by another manufacturer. It identifies the glass construction, including the color and thickness."
DOT 129: :The DOT code (DOT number) is the letters “DOT” followed by a number that the Department of Transportation (National Highway Traffic Safety Administration) assigns to the manufacturer of the glass. This is required by FMVSS205 section S6.2. If you have a DOT code, here's a page that lists all known DOT codes."
DOT number search: DOT Number Database
Viracon shut down it's auto glass division in 2007, so finding cross-reference or application guide information is very difficult. Auto glass firms may have a cross-reference guide or on-line access to such information, but I couldn't find it. A better source may be those specializing in Cobras and parts, like Cobra Restorers or Finishline.
There's a thread from 2009, where Scufty was looking for a windshield for his Butler - presumably the same was used for Arntz Cobras:
help with windshield
Post #5, Scufty wrote "the previous owner ordered a replacement glass from Cobra restorers Part Number CP1363."
Post #6: Scufty (Butler Cobra) posted that his windshield markings were:
Velas Laminated
43R 00003
As-1 M6 Dot 73
Post #14: 289ACE (2 AC Aces) posted that his was:
Viracon
Laminated
ASI M-60 DOT 129
Made In USA
4 24
This is probably not of any value, as the Viracon M-60 is almost certainly a different windshield than your Viracon M40.
