Like Tree1Likes
  • 1 Post By HTM101
Old 08-13-2019, 10:26 AM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Default Clutch pushrod "bullet"
need to find the "half ball" that goes on the clutch rod that pushes on the throw-out fork. I have the ford arm with a large detent for the rod end with the hole in the center of the detent.
Just spent hours searching and came up with nothing . The "half ball" must be larger than a chevy rocker arm pivot ball ,which would work, but it goes through the hole in the arm.
Any body know what I'm talking about ?
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 08-13-2019, 10:41 AM
Like these? https://mobiletekkdemo.com/fp/produc...ford-fox-sn95/
Old 08-13-2019, 10:48 AM
Sorry Motorhead, those are pivot bolts.
But this thread today has a really nice setup made by Fortes though.
TKO600 / 351W block clutch slave cylinder
Old 08-13-2019, 11:26 AM
Senile Club Cobra Member
Chevy V8 rocker arm ball. Any NAPA.
rick@autoventureusa.net
Old 08-13-2019, 12:22 PM
MOTORHEAD's Avatar
Spd brake: those are pivots (fulcrum) for the throw out arm. I need a part that would look like just the rounded portion with a hole thru it.
MKIV. The chevy/ford rocker ball pivot is too small, goes right thru the hole in the outboard end of the arm.
Thanks for the replies
Ted
Old 08-13-2019, 01:39 PM
Will this fit your setup?
https://www.csxparts.com/p-640-clutc...uster-nut.aspx
Mongoose930 likes this.
Old 08-13-2019, 06:40 PM
Dwight's Avatar
Smile
I just installed one on a 67 Fastback Mustang. Big block with top loader.
Check this out to see if it's what you need.
https://www.ebay.com/itm/Clutch-Fork...8AAOSwzLZdLVnJ
Old 08-14-2019, 09:21 AM
MOTORHEAD's Avatar
Thanks for the leads guys, I'll check them out. One of them should do the job.
Ted
