March 2025
30 31
Like Tree2Likes
  • 2 Post By Karl Bebout
Old 12-04-2020, 03:36 PM
Danr55's Avatar
Default ouch...again
I guess I will be the first one in the club to have a new tremic transmission. Broke a transfer shaft.
Dan in Arizona
CCX3209
Old 12-04-2020, 04:26 PM
Cobra Make, Engine: FF Mark I, sprint car 347
At least the new ones shift smoother from what i understand.
Old 12-04-2020, 07:22 PM
Karl Bebout's Avatar
Get ur $4K together
I know, I know, the TKX isn't that much, but you'll find a way to spend it anyway. Why not a T56 since you're spend a wad?
I'd luv one.
Karlos
Old 12-04-2020, 08:43 PM
Alfa02's Avatar
Gold Star Contributor
Sorry to hear this Danny Boy. You get to be the Guinea Pig. Karlos anybody can drop a T-56 in, See Mr. Bebout you don't need a BB Chevy, to break stuff Danr's FE did just fine Plus Danr get's to try something NEW, that worth 4+K right there The Rot.
Old 12-04-2020, 11:07 PM
xb-60's Avatar
Aren't Tremec transmissions made in Mexico? Why buy (another?) Tremec?
You could have a bulletproof Toploader, new, from David Kee for $2450
Cheers!
Glen
Old 12-05-2020, 04:46 AM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
Cheers!
Glen
No overdrive and the TKX is a direct bolt in for the TKO-500/600. If it happens to me, I'd do the same.
Old 12-05-2020, 07:09 AM
Sorry to hear that Dan. Perhaps a rebuild at trans shop? It lasted a long time originally.
AZ Bob
Old 12-05-2020, 09:51 AM
As I think about Danr's issue, I'm just totally baffled how this could have happened, considering how much the car sits in his garage
Scotchman and moore_rb like this.
Karlos
Old 12-05-2020, 12:28 PM
hauss's Avatar
Tell us more Like what you were doing when you broke the shaft?
Old 12-05-2020, 01:29 PM
Gaz64's Avatar
Sorry to hear this has happened.
Seems a bit odd to still have the rear of every tooth intact, like the input shaft teeth are not used for their total width?
Normally when this happens from torque, a tooth with a fracture point fails, and then the following teeth all fail as a consequence.
Old 12-05-2020, 02:49 PM
Danr55's Avatar
I was shifting from second to.third under a medium load when something snapped. Luckily I had forty miles to go to get home. Fourth a nd fifth gears didn't seem to be affected.
Dan in Arizona
CCX3209
