January 2025
26 27 28 29 30 31
Like Tree2Likes
  • 1 Post By Paintwerks
  • 1 Post By Zedn
Old 10-07-2013, 03:09 AM
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Default Can you fit this......
So, I was browsing fleabay and came across this:
Chevy Turn KEY SBC 427 Stage 5 0 Dart Block Heads Crate Motor 605 HP QRP Rated | eBay
Seems like a great deal from a reputable seller/builder. Is there any way you could register/comply this in a brand new Cobra such as my (shortly inbound) Pace 427SC??
TIA!
d488y2 likes this.
Old 10-07-2013, 03:33 AM
sambo's Avatar
Stick with an AU delivered engine with a factory ECU + tune if you are required to pass the IM240 test. Your engineer is the best person to ask.
"A spectacularly fast car in a grand if dated tradition."
Old 10-07-2013, 03:53 AM
d488y2's Avatar
Cobra Make, Engine: Cobra Replica, 5.0 Supercharged Coyote
Will be interested to see what your engineer says.
Old 10-07-2013, 04:07 AM
750hp's Avatar
Can't help regarding engineering, but have to say that the engine looks like great value considering the parts fitted!
Engines at this price often have seasoned blocks and Pro-Comp garbage cylinder heads and no-name rotating assemblies, so Dart and Scat parts are a big improvement!
Craig
Old 10-07-2013, 04:38 AM
Zedn's Avatar
No. Has no emissions controls on it and i doubt it would be possible to get a carb through the IM240 test.
That is unless you plan on using a club permit.
boxhead likes this.
Old 10-07-2013, 05:00 AM
Cobra Make, Engine: Dax
I wouldn't buy it if it were mine, and there's not many possible loopholes I haven't investigated.
As it's a new block, it'll need a new engine number, and so it'll need to be as compliant as a new engine; carbs certainly wouldn't be compliant.
Long and short of it would be to spend your money on compliant stuff.
Treeve
