November 2024
Like Tree5Likes
  • 2 Post By Zedn
  • 2 Post By Modena
  • 1 Post By LoBelly
Old 04-05-2014, 08:26 PM
sjelby's Avatar
Default under gaurd protection
What if anything has everyone used as a stonechip protection on the underside of the fiberglass guards?
Stan.
Old 04-05-2014, 09:18 PM
Wazza's Avatar
I've used "Rhino Lining"
Protective Coatings, Epoxy Flooring, Seamless Flooring | Rhino Linings
Not cheap...a bit of rooting about...but looks good and works well.
Superformance ( and others) have also used what is basically "Wet suit rubber" glued under the guard.
I recon that would work well also.
Warren
Old 04-05-2014, 10:12 PM
Zedn's Avatar
i went wetsuit material glued on with sikaflex under the main area of the guard that stones will go. I then coated the entire underside with primer, then coated with a spray on body deadener that used a gun that screws onto the bottle (shultz gun?). Then painted over with gloss Por 15 black. There are a few different body deadeners/stone guards, not all are paintable though. The one i used was water based.
The finish is super hard from the pro 15 and the body deadener and foam provide some insulation. Looks really nice and fairly inexpensive. I think the gun was only about $20 from memory.
sambo and Rog246 like this.
Old 04-06-2014, 12:45 AM
fordracing65's Avatar
Kirkham sells an under fender lining...
PRIDEnJOY
Old 04-06-2014, 02:55 AM
BMK's Avatar
BMK BMK is offline
CLARK Rubber have an adhesive rubber product that is about 8mm thick. Comes in sheets and is quite expensive as it has sound deadening qualities as well.
Worth a look..
Bernie Knight
Old 04-06-2014, 03:35 AM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
well I did 6 coats of under body deadener
front & rear
so get back to building stan
rob
not all your babies are your children
Old 04-06-2014, 04:29 AM
Dimis's Avatar
Worth a look..
Bernie,
Did you use this... Or the Kirkham supplied underliner?
Old 04-06-2014, 04:38 AM
Modena's Avatar
I used brush on deadener from Super Cheap Auto, It came in a 4 litre tin, think it was about $50 from memory. To do all 4 under guards I used about 1/2 the tin, single coat, this stuff is like a tar paste and it went on about 3mm thick. I used $0.50c brushes from Bunnings so I didn't have to bother cleaning them (wash-up is turps).
Dry finish is matte and rough.
750hp and Gav like this.
Ben in AU
Old 04-06-2014, 02:04 PM
BMK's Avatar
BMK BMK is offline
Dimis,
I have used some of this over the Kirkham deadener as these areas are target spots for stones being thrown out of the tread.
Bernie Knight
Old 04-06-2014, 04:48 PM
LoBelly's Avatar
I used generic spray paint from a can
No damage so far despite some pretty severe provocation
LB
Gav likes this.
Old 04-07-2014, 05:56 AM
07cob's Avatar
Stan
6mm neoprene on four corners. All good so far.
Geof
