January 2025
26 27 28 29 30 31
Like Tree3Likes
  • 1 Post By NorcalLmo
  • 1 Post By rbgray1
  • 1 Post By studebaker53
Old 10-14-2016, 01:36 PM
Cobra Make, Engine: Classic Roadsters, 351W blueprinted
Default Replacement pedals for Classic Roadster
I recently attended a car show where the Cl Cobra had a much better set of pedals ( gas, clutch and brake) than originally came with my 1992 CR
Any suggestions on where to purchase?
Also thinking about changing to hydraulic clutch . Thought?
As always all help , suggestions, and insights are very much appreciated.
Tom
Living, loving and Freezing in Minnesota
Old 10-14-2016, 01:53 PM
Cobra Make, Engine: Cobra n Vettes, 1966 Cobray C-3 running gear, 355 SBC TH-400
Default **Pedal assembly question**
I have a 'roller' kit and I'm trying to determine who offers the WHOLE pedal assembly for - clutch, brake and gas - also the E-brake handle assembly - any recommendations / part numbers / suppliers / pictures would be VERY APPRECIATED!!!!
SnakeDoc likes this.
Old 10-14-2016, 05:36 PM
rbgray1's Avatar
I believe if you go to one of DVs posts, you will see the hydraulic assembly installed on Capt Eddies car.
DV...can you help with the part number identification.
Old 10-14-2016, 09:41 PM
My suggestion is if you go hydraulic, use an external slave cylinder. The internally mounted hydraulic throwout bearing requires a ton more work if needed to be replaced.
Old 10-16-2016, 06:44 PM
Default hanging pedal assembly for CR
I have a spare hanging pedal assembly for a Classic Roadster if anyone needs it. I went with something else.
