1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
5Likes
Post By Hapnyny
Post By Chicagowil
Post By sunman
Post By Chicagowil
Post By Dominik
09-22-2023, 05:50 AM
Oh
Cobra Make, Engine: Classic roadsters 1991
Front wheel offsets
So I purchased the shelby wheels for the classic roadster cobra, they are 5" offset on front, they seem to be in from the fender lip, its a 1991 kit, what are you all running for front offsets?
09-24-2023, 05:21 AM
Same.
09-30-2023, 05:07 AM
NC
Cobra Make, Engine: Classic Roadsters, 347 stroker
Have not bought mine yet, but will use 5" as my starting point. I have an offset calculator tool to get the widest tire all around while still keeping the tire/rim inside the lip. Its all about stance right?
09-30-2023, 07:35 AM
WI
Vintage wheels sells the choice for CR as:
Front- 2 x 15 x 8 with 5.0 backspace
Rear- 2 x 15 x 10 with 6.0 backspace
The wheels that came with the CR kits typically were 15" X 8" with 3.75" backspace.
Thom
"Still plays in the garage"!
09-30-2023, 11:25 AM
Oh
Wheel offset
These are the wheels I have, I have 5" on front, with a 2" spacer it puts it where it should be
09-30-2023, 05:11 PM
Ok
I’ve got Compomotive 16 x 8 on the front 3 3/4” backspace recommend by Don Scott
Fits great no more tire room on outside and inside has 1” or maybe more extra tire space.
 Chaney Shores Studio
09-30-2023, 05:13 PM
Oh
Wheel offset
Left 5" backspacing with 2" spacer, right side stock 5" backspacing
10-02-2023, 11:02 AM
Now the key is the allotment.
Reason: Attachment needed.
10-02-2023, 07:21 PM
WI
I am still wrestling with my choice for wheels.
Several years ago, I purchased a set of used 5 pin knock off Cobra II wheels. They came with the adapters. They are front- 7.5 X 15 & rear 9.5 X 15. When I finally got around to test fitting them, I discovered the fronts were a good fit, but the rear stuck out about almost 2"!
Now I have a choice of narrowing the rear end by 2" per side or selecting completely different wheels.
And, as I consider my choices, I keep in mind that tire choices in 15" are quickly reducing.
I have a pair of American Racing torq Thrust chrome 9.5 X 17 wheels. They look nice with the paint & chrome side pipes. But they are not the Halibrand style knock off wheels. And a new pair for the front are about $300 each. That is about the cost of narrowing the rear end with new axles.
My car, being a CR I, is not an exact replica by any means. It is more similar to an 80's AC Cobra from the UK that has been stretched. Wide body, full dash, small block 302 w/EFI, & T5.
If you Google "Sunburst wheels" on Holley's site, it shows a CR in green with the Sunburst 5 lug wheels. It would be my choice- but they seem to now be out of production.
Decisions, decisions!
Thom
10-02-2023, 11:46 PM
wheel offset ET backspacing tool
If I don't respond anymore, that's because I can't log in
Thread Tools |
Display Modes |
Linear Mode
