Go Back   Club Cobra > Engine Building, Tuning, and Induction > Holley Tuning
January 2025
26 27 28 29 30 31
Like Tree5Likes
  • 1 Post By patrickt
  • 3 Post By patrickt
Old 01-04-2022, 02:21 PM
Cobra Make, Engine: ERA #720
Default 4160 Question
I was rebuilding my 4160 carb (3310-11) and there is this sticker/gasket over one of the holes in the body of the carb. I had a new replacement in the kit so I pulled it off assuming that the new one would have an adhesive back on it. When I tried to peel what I thought was the backing off I just tore the replacement. I called Holley yesterday and spent an hour on the phone and got nowhere and then was disconnected. So my questions are:what does this thing do? Does anyone know what the part number is? If it's only function is to block off a hole can I just block it off by some other means and move on? I've attached a pic of the hole it was over as well as what the old one looked like resting where it was. Any info would be appreciated. Thanks
Old 01-04-2022, 02:43 PM
I've never seen that. Try Googling some pics of the 4160, of which there are a zillion, and see if you can either find a pic of it or a pic of the hole that it was covering and post a link to that.
Old 01-04-2022, 02:58 PM
Patrickt - See above, I tried one last thing and it worked. Any input would be appreciated.
Old 01-04-2022, 03:10 PM
Gaz64's Avatar
Yes, I thought that's what you would looking for.
That stick-on piece is used on manual choke carbs to seal a manifold vacuum source that is used for automatic choke models.
It comes as a sticky, to help assembly. You can make it yourself, out of a piece of gasket paper, and bond it with a smear of contact adhesive.
The clamping of the manual choke assembly mounting keeps it sealed.
Gary
Gary
Old 01-04-2022, 03:14 PM
Dang, I thought we were talking about the inside of the carb. I would have flunked that quiz.
Gaz64 likes this.
Old 01-04-2022, 03:55 PM
Here's a decent shot of mine from the last time I rebuilt my 4160. BTW, I have the manual choke mostly removed and the butterfly zip tied in the full open position.
rads42 likes this.
Old 01-04-2022, 04:09 PM
eschaider's Avatar
Load the pic to your pic gallery in the CC member galleries and then use the linked image code below the pic to paste into the dialog box you see when you click on the Insert Image icon in the tool bar above the message box you are typing your thread response in. Presto, voilą!
Ed
Old 01-05-2022, 08:00 AM
Gary
Perfect answer, I have a manual choke carb so that all makes sense. I'll make something and move on. Thanks to all for your input, much appreciated.
Old 01-05-2022, 08:40 AM
The absolute best, most productive, and wonderful modification you can make to your 4160 is to add a small adjustable set screw to the base of the secondaries (replacing the one that's already there) that will allow you to control your idle via that screw while leaving the primaries perfectly set in the transition slot. Here is a pic of mine and here is a lengthy thread where I help someone get his 4160 absolutely perfect.
Best Way to set the idle mix on a 4160
rads42, eschaider and FredG like this.
