Go Back   Club Cobra > Engine Building, Tuning, and Induction > Ignition
January 2025
26 27 28 29 30 31
Like Tree3Likes
  • 3 Post By carmine
Old 02-01-2018, 03:49 PM
Default Recurving
The last post I submitted concerning my ignition problems with the MSD system with the mechanical advance, I decided to go back to a vacuum advance distributor for the 428 CJ the only difference is the use of the Pertronix Ignitor II module, I have another distributor that is all stock with points. Looking for thoughts on recurving both distributors.
Old 02-01-2018, 09:23 PM
Gaz64's Avatar
Can you provide compression ratio, cylinder heads, camshaft specs, carburettor, trans, diff ratio, tyre diameter, etc etc?
Gary
Old 02-02-2018, 05:44 AM
DanEC's Avatar
Assuming you have a pretty much stock 428 CJ, I've found 12 degrees initial advance and 24 centrifugal to work pretty well for the engines in my assortment of cars with a vacuum advance distributor. I believe from memory that when I had Tim O'Connor restore the 427 dual point (no Vacuum advance) distributor for my ERA, he either found it at - or modified it to - 20 degrees centrifugal advance. So I run around 16 degrees initial. Without vacuum advance this works pretty well. The engine turns over and starts fine and the additional initial advance compensates partly for the lack of vacuum advance at idle. Tim is a good source if you want a professional rebuild of your stock distributor and custom advance built in.
This is my experience. No one, single, correct answer to this question.
ERA 782 Running
Old 03-29-2022, 03:31 PM
Cobra Make, Engine: spf 2112 *427 stroker windsor
i had problem with my MSD distributor so i ripped everything out and replaced with PROGRESSION IGNITION all in one Electronic Distributor.
No more MSD box.
No more bundle of wires to route.
Reads manifold vacuum.
Down load the app for your phone and change your map on the fly while driving.
Greatest thing since sliced bread.
Ps: I run 48 IDA Webers! ( all i can say is WOW)
https://progressionignition.com/
NROTOXIN, eschaider and cycleguy55 like this.
