December 2024
Like Tree1Likes
  • 1 Post By blykins
Old 09-22-2020, 04:14 AM
Default Lykins Motorsports 418W, 540 hp, 586 lb-ft
Did this one a few months back...
Factory 351W roller block, with a Scat 4340 4.100" stroke crankshaft. K1 rods, with Mahle pistons. One of my custom hydraulic roller camshafts with OEM style Ford Racing hydraulic roller lifters. AFR 220cc cylinder heads with a Performer RPM Air Gap intake.
Customer will change to throttle body EFI after installation, but we dyno'd this one with a Holley 830 dyno carb.
Peak hp was at 5700 rpm.
Phx Mike likes this.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 09-22-2020, 06:39 AM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
Nice.
Do you sell the valve covers? Are they aluminum?
Old 09-22-2020, 08:25 AM
Yes, when available. They are Blue Thunder, cast aluminum, and hard to get a hold of.
Old 09-22-2020, 09:37 AM
Karl Bebout's Avatar
Do you have any concerns about the 2 bolt mains with that much torque output? That's a bunch.
Karlos
Old 09-22-2020, 09:40 AM
No sir, I've built quite a few at that level without issue. If it were a higher rpm drag race engine or similar, then I think an upgrade would be prudent, but it's just a street cruiser on street tires.
Old 09-22-2020, 02:54 PM
Neutral
I figured you knew what you were doing. Keep cranking out that quality and HP!
Karlos
Old 09-22-2020, 09:37 PM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Very nice - Karl you should call Brent....I think you are due for an upgrade from your lil 289!
