December 2024
Like Tree1Likes
  • 1 Post By WildBill1965
Old 05-10-2012, 09:12 AM
skippy's Avatar
Cobra Make, Engine: SPF 1476 - Keith Craft 445ci, 636hp 613tq
Send a message via Skype™ to skippy
Default SPF Side Pipes. Pls Help
Hi guys,
I seriously need your help here.
I am looking to place a 4 disc silencer into my SPF standard pipes muffler area., Car Chemistry Shop
I need to know what the internal measurement area of the muffler is, will i need the 3.5inch or the 4 inch disc part to place inside.
Many thanks for the help, seriously appreciated.
Skip
Old 05-10-2012, 11:13 AM
try 2" the front of the muffler looks like a rectangle than opens up, main section of muffler is 2" or 1 3/4"
Old 05-10-2012, 11:14 AM
easy decision, none of theirs will fit stock mufflers, i guess you could put it after that would be 3"?
Old 05-11-2012, 09:41 AM
skippy's Avatar
Thxs Madmaxx,
I was actually thinking it might be 4inch as i was told that the tail down turn was 3.5inch and runs into the end part of the muffler that was 4inch, but i wanted to make 100% sure here...
I will try and find another solution...
Really appreciate your effort..
Skip..
Old 05-11-2012, 10:58 AM
The stock sidepipes already strangle that engine.
Why do you want to further strangle it? The stock SPF muffler is a maximum 2" in diameter. About perfect for a mild 302. Your engine needs at least 3" to even begin to breathe like it should.
Why have that big horsepower motor if you won't let it breathe?
Jim
Old 05-11-2012, 02:47 PM
skippy's Avatar
Hi Jim,
Its to get the Cobra through the inspection process, its just for the day, once every 2 years.
I have Ron Roberts perfect pipes that let the Snake spit its venom.
Guess i should have given the reason before raising other eyebrows.
Cheers.
Skip.
Old 05-19-2012, 08:15 AM
For inspection purposes: Fix It Ticket For Loud Exhaust. - YouTube
Old 05-21-2012, 05:14 AM
skippy's Avatar
Thanks, i used to have it in the past, but now i added the engine i was worried about the serious back pressure.
Old 05-22-2012, 08:41 PM
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Don't need all that much steel wool, use the coarse kind, to remove take out the restictor device and crack the throttle! Oh and make sure no one standing next to pipes.
B i l l
skippy likes this.
Old 05-24-2012, 02:32 PM
PANAVIA's Avatar
Maybe a custom solution >?
Old 05-24-2012, 11:43 PM
skippy's Avatar
Steve,
Seeing a welder this weekend. Keep you posted on the final outcome.
Thxs gents.
Skip.
