05-04-2024, 07:20 PM
Cobra Make, Engine: SPF#0760
Yes, The latch’s tend to loose over time. I’ll assume that when working properly it closed easily. (Door not out of alignment) that can cause it to loosed if latch is mis-aligned.
You mentioned your car is a 2000 model year. There are a few things you should check on an older car. Contact me offline and I can help you out.
Blas
SPFWiringDiagrams@Comcast.net
