04-12-2022, 11:26 AM
NJ
Cobra Make, Engine: ERA 427, 482ci sideoiler
Could be the bushing in the tail shaft housing or the slip yoke are worn which will accelerate the wear of the tail shaft housing seal. First check the level of the lube, over filling will cause leaks. Also, make sure you have a vent, OEM is just a small hole approx. 1/8” in the top cover of the main gearbox housing. Some tail shaft housings were also upgraded with a vent on the top of the tail shaft housing a couple of inches back from where the housing attached to the main gear box. If the lube level is correct and you have a vent, the problem is likely the bushing and or yoke and a new seal. The bushing, seal and yoke can all be easily replaced. Make sure the lube is leaking at the seal to yoke and not the seal to tail shaft. If leak is at the tail shaft where the seal is driven into the housing, a new seal and a lite application of the “right stuff” on the o.d. of the seal prior to driving it into the housing should suffice, if the bushing and yoke are in good shape. One other remote possibility could be a bent output shaft, don’t go down that rabbit hole until you have ruled out all the easy fixes first.
